agreed on a colder heat range.
the one thing you've not thrown on the table is the stock CDI unit.
changing the base timing and the curve with a different controller may be a better direction.
you've put the motor into areas the stock CDI isn't designed for.
i bet it's just adequate
issue is, your location won't allow for easy trial and error.
> Toby B Wrote:
> I welcome any and all input!
