Toby B Wrote:
> Part Deux
> So after deciding that it’s not safe to play
> with cars that are capable of rolling over me even
> at my 24mph top speed, I decided it was time to
> get serious with some power improvements. Well
> actually, in truth, I just have a bad habit of
> ploughing money into modifying cars, and even
> though it’s only 2.5hp, the Motocompo hasn’t
> escaped the same attention!
> There is a fella in Japan that hand builds
> expansion chambers for these critters, which are
> claimed to yield a 6mph improvement. The only
> downside was the cost, which at USD$300+ makes
> them a little bit pricey. All the more so when it
> arrives on your desk at work and you discover
> it’s barely larger than your keyboard! So after
> a few weeks of procrastination, I found some time
> to fit the pipe, and made the effort to wrap it in
> exhaust header, since even the standard mufflers
> are known to get hot enough to melt the plastic
> fairings.
> Now, with no other changes to the bike I was able
> to pick up 8km/h (5mph) on the top end to increase
> to 46km/h / 28.5mph. It is worth noting that my
> tyres were definitely a little flat due to
> sporadic use, and so I think I could have hit
> 30mph had the tyres been properly inflated. I have
> since pumped them, and so will do one more run to
> confirm top speed before moving onto the next
> phase of the project.
> For the next post I’ll also include some pics of
> the Vapour Trail Tech that I installed to keep an
> eye on all systems, plus update on my 70cc plans!
Did you Upjet/make jetting changes when you put on the performance pipe? seems like you should've got a lot more performance, are you running a performance mesh filter ? If you change the exhaust output you got to change the input of the carburetor/air filter to match.
I suggest you get a head temperature gauge to aid in tuning and to keep you from locking your engine up as well as finding a way to gear higher for more top speed
