Rpms without tachometer
Nathan Hadfield /
How do I determine rpms without tachometer. Seriously guys. Don't really need the I'm a dumbass because I'm new at this.
77Puch
70cc
17x40
Re: Rpms without tachometer
77Puch 49cc 17x40 = RPM = RPM displacement has nothing to do with it...
if it's less than 20 rpm you can count
Casseroller Marty built a great gearing to rpm calculator web app
https://toolbox.martysgarage.info/
Probably Fred /
Tire diameter(in inches) is the very outside diameter of the tire, not the rim. A 2.25x17 is typically around 21"ish. (edited)
your clutch is tuned for take off youre engine is revving higher than with stock clutch at the same speed
