Re: decent led headlamp diy for Puch
Marc Friedman /
D
Ok so this is the Larsen high /low iie two level led tractor light as powered by as I've said the only way I know how to make this stuff work ie floated 12 v coil ( hpi mini here but I get exactly the same with a kinetic floated light coil on my y grande. ) Fed on this bike Into a two wire trailtech to a silicon rectifier from what used to be RadioShack. Two wire dc respecting the POS /neg clearly labeled on the Larsen light.
It's nice looking light that has a pretty nice in adulterated soft field that is great for moderate speeds in the dark.
I have an equally bright led set up on my Puch using Chinese motorcycle led bulb with a built in fan painstakingly into a hollowed out cev bulb but why all the effort. The Larsen is a plug and play if you give it DC and know what's positive and what's neg. So yea it's a wiring project.
  decent led headlamp diy for PuchTopic by: Brad William Brad William 07/11/17 08:31PM
  Re: decent led headlamp diy for PuchRe: Aron Chaudiere Aron Chaudiere 07/12/17 11:29AM
  Re: decent led headlamp diy for PuchRe: Dave Steele Dave Steele 07/12/17 12:44PM
  Re: decent led headlamp diy for PuchRe: frank dadog frank dadog 11/21/17 09:15PM
  Re: decent led headlamp diy for PuchRe: will warn will warn 07/12/17 01:41PM
  Re: decent led headlamp diy for PuchRe: Brad William Brad William 11/21/17 08:18PM
  Re: decent led headlamp diy for PuchRe: Charlie BUZZARD Charlie BUZZARD 11/26/17 12:27PM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 11/26/17 12:29PM
  Re: decent led headlamp diy for PuchRe: Dirty30 Dillon Dirty30 Dillon 12/01/17 09:07AM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 11/23/17 02:07AM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 11/23/17 02:11AM
  Re: decent led headlamp diy for PuchRe: frank dadog frank dadog 11/23/17 09:51AM
  Re: decent led headlamp diy for PuchRe: Brad William Brad William 11/24/17 07:45PM
  Re: decent led headlamp diy for PuchRe: frank dadog frank dadog 11/24/17 09:09PM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 11/24/17 09:59PM
  Re: decent led headlamp diy for PuchRe: Brad William Brad William 11/25/17 02:41PM
  Re: decent led headlamp diy for PuchRe: frank dadog frank dadog 11/25/17 03:26PM
  Re: decent led headlamp diy for PuchRe: Brad William Brad William 02/01/18 11:49AM
  Re: decent led headlamp diy for PuchRe: Brad William Brad William 02/01/18 12:03PM
  Re: decent led headlamp diy for PuchRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 11/26/17 09:43AM
  Re: decent led headlamp diy for PuchRe: Charles Cole (OFMC) Charles Cole (OFMC) 12/01/17 01:32AM
  Re: decent led headlamp diy for PuchRe: Born to be WillD Born to be WillD 12/04/17 12:05PM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 12/04/17 12:37PM
  Re: decent led headlamp diy for PuchRe: Bad Cadillac™ Bad Cadillac™ 12/01/17 07:03AM
  Re: decent led headlamp diy for PuchRe: Graham Motzing Graham Motzing 12/01/17 01:15PM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 12/03/17 01:27AM
  Re: decent led headlamp diy for PuchRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/03/17 08:48AM
  Re: decent led headlamp diy for PuchRe: Graham Motzing Graham Motzing 12/04/17 10:44AM
  Re: decent led headlamp diy for PuchRe: Graham Motzing Graham Motzing 12/04/17 10:45AM
  Re: decent led headlamp diy for PuchRe: simon judd simon judd 12/06/17 12:00PM
  Re: decent led headlamp diy for PuchRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/01/18 12:13PM
