Re: decent led headlamp diy for Puch
Marc Friedman /
Stop torturing yourself!! Go down the rabbit hole with me to a secret world of linear electron travel a long step away from it's inherent wave nature.
And please follow this proven by the clutz of the century --me in this best way learned is always the hard way. All substitutions are on you.
1. Known 50- 60 watts electric coil that can be or better is FLOATED .
2. Two floated ends to five wire volt reg/ rectifier ONLY TRAILTECH do not substitute unless u know equivalence or better. The DC out ( one of the five wires isn't really moped critical ) and the output to quality led.
3. Headlight is definitely Larson lighting. I can't find a even vaguely quality build. But make sure you follow the polarity perfectly
4. #3 means no frame ground for anything but the ignition coil. So yea u better understand and get what's needed for a decent loom or if careful mod of existing wiring. A recent poster told me using a combo of existing 40 yo loom and new jumps for 12 v dc when maybe it was 6 v ac is gonna fry the coil. So far so good. Led wiring dc can be a bit smaller gauge esp to other than the 35 w DC headlight which is quite bright.
5. The original brake light is now led require NOT using power off backside of ignition coil unless u possess advanced degrees in theoretical physics, the brake switches need change to reverse and because lack of frame ground, yup more freaking wires near ur controls to be unable to hide.
But the light is fabulous. I couldn't get enough from halogens or mult hone made LEDs to survive though my Magnum has still a chinese led with a ballast grafted into a cev 6 v light with the oem guts removed and the led with it's own fan is mounted. That's the five wire trailtech and the general smoothnees of it's amazing build keeps it working whereas on my vespa s with more vibration from that motor is quite prone to poof I'm permanently dead quickly.
  decent led headlamp diy for PuchTopic by: Brad William Brad William 07/11/17 08:31PM
  Re: decent led headlamp diy for PuchRe: Aron Chaudiere Aron Chaudiere 07/12/17 11:29AM
  Re: decent led headlamp diy for PuchRe: Dave Steele Dave Steele 07/12/17 12:44PM
  Re: decent led headlamp diy for PuchRe: frank dadog frank dadog 11/21/17 09:15PM
  Re: decent led headlamp diy for PuchRe: will warn will warn 07/12/17 01:41PM
  Re: decent led headlamp diy for PuchRe: Brad William Brad William 11/21/17 08:18PM
  Re: decent led headlamp diy for PuchRe: Charlie BUZZARD Charlie BUZZARD 11/26/17 12:27PM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 11/26/17 12:29PM
  Re: decent led headlamp diy for PuchRe: Dirty30 Dillon Dirty30 Dillon 12/01/17 09:07AM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 11/23/17 02:07AM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 11/23/17 02:11AM
  Re: decent led headlamp diy for PuchRe: frank dadog frank dadog 11/23/17 09:51AM
  Re: decent led headlamp diy for PuchRe: Brad William Brad William 11/24/17 07:45PM
  Re: decent led headlamp diy for PuchRe: frank dadog frank dadog 11/24/17 09:09PM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 11/24/17 09:59PM
  Re: decent led headlamp diy for PuchRe: Brad William Brad William 11/25/17 02:41PM
  Re: decent led headlamp diy for PuchRe: frank dadog frank dadog 11/25/17 03:26PM
  Re: decent led headlamp diy for PuchRe: Brad William Brad William 02/01/18 11:49AM
  Re: decent led headlamp diy for PuchRe: Brad William Brad William 02/01/18 12:03PM
  Re: decent led headlamp diy for PuchRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 11/26/17 09:43AM
  Re: decent led headlamp diy for PuchRe: Charles Cole (OFMC) Charles Cole (OFMC) 12/01/17 01:32AM
  Re: decent led headlamp diy for PuchRe: Born to be WillD Born to be WillD 12/04/17 12:05PM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 12/04/17 12:37PM
  Re: decent led headlamp diy for PuchRe: Bad Cadillac™ Bad Cadillac™ 12/01/17 07:03AM
  Re: decent led headlamp diy for PuchRe: Graham Motzing Graham Motzing 12/01/17 01:15PM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 12/03/17 01:27AM
  Re: decent led headlamp diy for PuchRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/03/17 08:48AM
  Re: decent led headlamp diy for PuchRe: Graham Motzing Graham Motzing 12/04/17 10:44AM
  Re: decent led headlamp diy for PuchRe: Graham Motzing Graham Motzing 12/04/17 10:45AM
  Re: decent led headlamp diy for PuchRe: simon judd simon judd 12/06/17 12:00PM
  Re: decent led headlamp diy for PuchRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/01/18 12:13PM
