decent led headlamp diy for Puch
Brad William /
Not exactly drop in. Would be nice to find a really high performance 1156 LED true "drop in" but I haven't seen one yet
http://www.homedepot.com/p/Philips-50W-Equivalent-Bright-White-MR16-LED-Energy-Star-Light-Bulb-461509/207106557
If you cut a hole in the back of the light, the black plastic half of the assembly, exactly the diameter of the bulb just under the lip (the second widest point in the image above) when the bulb is dropped into that hole snugs against the glass reflector perfectly and concentrically when the reflector is screwed back on.
Direct wired to the harness it works wonderfully. The circuitry inside makes it flicker free, good light at idle, and very good light at speed. Nice spread angle looks natural as well.
  decent led headlamp diy for PuchTopic by: Brad William Brad William 07/11/17 08:31PM
  Re: decent led headlamp diy for PuchRe: Aron Chaudiere Aron Chaudiere 07/12/17 11:29AM
  Re: decent led headlamp diy for PuchRe: Dave Steele Dave Steele 07/12/17 12:44PM
  Re: decent led headlamp diy for PuchRe: frank dadog frank dadog 11/21/17 09:15PM
  Re: decent led headlamp diy for PuchRe: will warn will warn 07/12/17 01:41PM
  Re: decent led headlamp diy for PuchRe: Brad William Brad William 11/21/17 08:18PM
  Re: decent led headlamp diy for PuchRe: Charlie BUZZARD Charlie BUZZARD 11/26/17 12:27PM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 11/26/17 12:29PM
  Re: decent led headlamp diy for PuchRe: Dirty30 Dillon Dirty30 Dillon 12/01/17 09:07AM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 11/23/17 02:07AM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 11/23/17 02:11AM
  Re: decent led headlamp diy for PuchRe: frank dadog frank dadog 11/23/17 09:51AM
  Re: decent led headlamp diy for PuchRe: Brad William Brad William 11/24/17 07:45PM
  Re: decent led headlamp diy for PuchRe: frank dadog frank dadog 11/24/17 09:09PM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 11/24/17 09:59PM
  Re: decent led headlamp diy for PuchRe: Brad William Brad William 11/25/17 02:41PM
  Re: decent led headlamp diy for PuchRe: frank dadog frank dadog 11/25/17 03:26PM
  Re: decent led headlamp diy for PuchRe: Brad William Brad William 02/01/18 11:49AM
  Re: decent led headlamp diy for PuchRe: Brad William Brad William 02/01/18 12:03PM
  Re: decent led headlamp diy for PuchRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 11/26/17 09:43AM
  Re: decent led headlamp diy for PuchRe: Charles Cole (OFMC) Charles Cole (OFMC) 12/01/17 01:32AM
  Re: decent led headlamp diy for PuchRe: Born to be WillD Born to be WillD 12/04/17 12:05PM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 12/04/17 12:37PM
  Re: decent led headlamp diy for PuchRe: Bad Cadillac™ Bad Cadillac™ 12/01/17 07:03AM
  Re: decent led headlamp diy for PuchRe: Graham Motzing Graham Motzing 12/01/17 01:15PM
  Re: decent led headlamp diy for PuchRe: Marc Friedman Marc Friedman 12/03/17 01:27AM
  Re: decent led headlamp diy for PuchRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/03/17 08:48AM
  Re: decent led headlamp diy for PuchRe: Graham Motzing Graham Motzing 12/04/17 10:44AM
  Re: decent led headlamp diy for PuchRe: Graham Motzing Graham Motzing 12/04/17 10:45AM
  Re: decent led headlamp diy for PuchRe: simon judd simon judd 12/06/17 12:00PM
  Re: decent led headlamp diy for PuchRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/01/18 12:13PM
