Miguel,
If the idle screw is easy to access, take it out, remove the spring, screw it back in gently until you feel it toch something, then twost the throlle and screw it in another turn. If you can then adjust the idle speed, get a shorter spring from the hardware store.
Why the bigger jet? Are you running lean?
Ron
