Re: How often do you clean your carburetor?
I believe this would fall under my "as needed" catagory, because as they say, "If it ain't broke, fix it until it is", which is where you'll end up, with stripped threads, worn out screw heads, ruined gaskets, etc..., when you screw with stuff that you don't need to be. (edited)
  How often do you clean your carburetor?Topic by: Simon Belmont Simon Belmont 04/17/17 03:41PM
  Re: How often do you clean your carburetor?Re: Moped Lar Moped Lar 04/17/17 03:43PM
  Re: How often do you clean your carburetor?Re: Stephen Keller Stephen Keller 04/17/17 03:48PM
  Re: How often do you clean your carburetor?Re: Andrew Squiggman Andrew Squiggman 04/17/17 06:59PM
  Re: How often do you clean your carburetor?Re: steve millar steve millar 04/17/17 03:50PM
  Re: How often do you clean your carburetor?Re: Simon Belmont Simon Belmont 04/17/17 03:54PM
  Re: How often do you clean your carburetor?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/17/17 04:01PM
  Re: How often do you clean your carburetor?Re: Born to be WillD Born to be WillD 04/17/17 04:51PM
  Re: How often do you clean your carburetor?Re: Wild West Pony Wild West Pony 04/17/17 05:49PM
  Re: How often do you clean your carburetor?Re: alex . alex . 04/18/17 01:16AM
  Re: How often do you clean your carburetor?Re: Bruce Zapper Bruce Zapper 04/18/17 06:53AM
  Re: How often do you clean your carburetor?Re: Ryan . Ryan . 04/17/17 06:56PM
  Re: How often do you clean your carburetor?Re: Bad Cadillac™ Bad Cadillac™ 04/18/17 09:58AM
  Re: How often do you clean your carburetor?Re: mit mortso mit mortso 04/18/17 10:00AM
  Re: How often do you clean your carburetor?Re: ~ DeeZy ~ DeeZy 04/18/17 10:34AM
  Re: How often do you clean your carburetor?Re: Rich Condor Rich Condor 04/18/17 10:36AM
