Re: What is the most gasoline you have spilled?
Thomas TPRF /
Dumped about two gallons on my porch when replacing fuel lines and the entire nipple bit popped out of a rusty tank. Hosed it all down with water to dissipate the fuel but the landlord had someone working under the house later that day and I got my ass crawled about it.
Also had a hose on my Comet rot through while at work. Came out to about 10 gallons having run down the storm drain. Oops.
  What is the most gasoline you have spilled?Topic by: Double Trouble Dan Double Trouble Dan 02/22/17 04:26PM
  Re: What is the most gasoline you have spilled?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/22/17 04:48PM
  Re: What is the most gasoline you have spilled?Re: no one of covfefe no one of covfefe 02/22/17 04:55PM
  Re: What is the most gasoline you have spilled?Re: P8R . P8R . 02/22/17 05:27PM
  Re: What is the most gasoline you have spilled?Re: Your pal DOOV Your pal DOOV 02/25/17 08:55PM
  Re: What is the most gasoline you have spilled?Re: Andrew Squiggman Andrew Squiggman 02/22/17 05:46PM
  Re: What is the most gasoline you have spilled?Re: Beach Club Nick Beach Club Nick 02/22/17 05:57PM
  Re: What is the most gasoline you have spilled?Re: Mike Stroz Mike Stroz 02/22/17 08:08PM
  Re: What is the most gasoline you have spilled?Re: sookia sookia sookia sookia 02/22/17 08:22PM
  Re: What is the most gasoline you have spilled?Re: Captain Janeway Captain Janeway 02/22/17 08:27PM
  Re: What is the most gasoline you have spilled?Re: Dan (high idle) Conway Dan (high idle) Conway 02/22/17 09:53PM
  Re: What is the most gasoline you have spilled?Re: Thomas TPRF Thomas TPRF 02/22/17 10:05PM
  Re: What is the most gasoline you have spilled?Re: grim ripper grim ripper 02/23/17 10:06AM
  Re: What is the most gasoline you have spilled?Re: todd amundson todd amundson 02/23/17 10:38AM
  Re: What is the most gasoline you have spilled?Re: Braap Master Mope Braap Master Mope 02/24/17 11:37PM
  Re: What is the most gasoline you have spilled?Re: Don Wayne (Ofmc) Don Wayne (Ofmc) 02/25/17 01:09PM
  Re: What is the most gasoline you have spilled?Re: no one of covfefe no one of covfefe 02/25/17 01:10PM
  Re: What is the most gasoline you have spilled?Re: * * * * 02/25/17 01:09PM
  Re: What is the most gasoline you have spilled?Re: Don Ohio Don Ohio 02/25/17 07:28PM
