Whats Your Top Speed?
Hey guys just outta curiousity what do are you guys getting on your mopeds? write down what moped if its stock/modded and top speed :)
My current moped
78 free spirit
stock-24 Mph
Re: Whats Your Top Speed?
Nice try, officer
Dano Staz /
?? its a serious question lol? and why would a cop care how fast a moped goes?
It's like 5 degrees outside right now.
That would make my top speed exactly 0.
Andrew Squiggman /
no moped exceeds 30 mph anywhere
MA Page speed .. warp factor 8.3... IRL speed ...43 mph ...yes , a well tuned 1-d will do this speed . (PS) book em Dano ... (edited)
Probably Fred /
> My current moped
> 78 free spirit
> stock-24 Mph
Stock should be like 30 mph and with tuning of your stock parts you can be near 40mph so get to work timing/tuning/jetting cause 24mph is feeble/out of tune
now now Ken lets not give the poor a guy a complex. gently explain how this can be achieved. wouldn't near 40mph still be considered feeble? near only counts with horseshoes, and hand grenades...
Probably Fred /
> grenades...
Most freespirits go 30mph or can if they are restricted not a 30mph model
A poor out of tuned 24mph is dangerous with traffic on 35 mph roads, cagers get road rage and pass you anywhere even blind hills and corners, make right turns into you, heck bicyclists will have conflicts with you too if you go that slow for you won't be able to pass them.
To be safe you need 30mph for 25mph roads and 35-40mph for 35mph roads
My puch Murray was the same set up as a Sears free spirit, it did it dismal 24mph when I got it and I got it to go 40 and literally break the speedometer by simple tuning using stock cylinder, carb and exhaust.
All I did was change the junk air box to a metal mesh filter then upjet the carburetor from a 68 with a #212a to 72 jet with #222 atomizer, needle position stayed the same as stock, make sure magneto was serviced and fiber pad lubed, set point gap 17 thou of a inch, set timing to 17.5° before top dead center and change the 15t front sprocket to Normal puch size 16 tooth.
Poor spark out of time and or jetting off just one size and you have a dog for a bike
A hr or two of work can double your hp you were making and Increase speed by 50-60%
My QT50 does 39mph on the flat but its not a moped :(
I hit 27 after porting but it takes years to get up to speed
Andrew Squiggman /
> up to speed
I call BS. 24 tops
My tomos goes mach speed and I don't live in NJ!
Poppycock!
Dano Staz /
thanks for the advice!!!
