Re: Urban Express 83 Wheel/Forks/Shocks Upgrade Help
Born to be WillD /
You could get a motorcycle frontend and wheel. Ninja uses 16" wheels and you can get a functional frontend + wheel for probably 200-500 bucks depending how much work it needs. a 110/90 16 is like just over 4 inches wide.
it'll be heavy as fuck and probably take a LOT of work to get it to fit, but would work out for the front. Wider on the back you can maybe do some tricky lacing offcenter to a wide rear rim. being that the engine and shock are same side you can probably push the wheel out. it'll screw up alignment some but should work anyway.
Alternately you can spend a fewq hours trying to research spline counts and sizes and see if you can find other hubs that could possibly work and then go back and make modify or buy wider offset ones. Might be some crossover with other bigger wheeled scooters if you're lucky but highly doubt it. still you could have some cuzzztom shit machined maybe?
Depending what you're trying to do performancewise DR kit is generally top pick, bang for buck, good performance and reliability and relatively easy setup. Then probably the MLM pipe is the only one that lets you keep your centerstand and mounts up directly.
Personally I'd just port it and use a hobbit circuit but that's cheap and less rewarding and you lose the stand.
  Urban Express 83 Wheel/Forks/Shocks Upgrade HelpTopic by: G V1983 G V1983 11/16/16 05:08PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Ryan . Ryan . 11/16/16 06:15PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Captain Janeway Captain Janeway 11/16/16 06:57PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Stephen Keller Stephen Keller 11/16/16 07:01PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: G V1983 G V1983 11/16/16 07:48PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 11/16/16 08:33PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: steven kline steven kline 11/18/16 04:02PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Captain Janeway Captain Janeway 11/17/16 03:53PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Captain Janeway Captain Janeway 11/17/16 03:54PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Ryan . Ryan . 11/16/16 07:52PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Jason Giragosian Jason Giragosian 10/22/18 03:52PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Captain Janeway Captain Janeway 10/23/18 01:59PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Jack Rutherford Jack Rutherford 10/23/18 08:58PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Ryan . Ryan . 11/16/16 08:44PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Scott Viers Scott Viers 11/16/16 09:32PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Stephen Keller Stephen Keller 11/16/16 11:15PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: G V1983 G V1983 11/16/16 11:22PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Born to be WillD Born to be WillD 11/17/16 09:41AM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Benjamin LaPlante Benjamin LaPlante 11/17/16 03:01PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: steven kline steven kline 11/18/16 03:58PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: G V1983 G V1983 11/21/16 09:05AM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Ryan . Ryan . 11/21/16 10:39AM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: G V1983 G V1983 11/21/16 10:48AM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Ryan . Ryan . 11/21/16 02:58PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Born to be WillD Born to be WillD 11/23/16 03:38PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: steven kline steven kline 11/23/16 04:04PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: Ryan . Ryan . 11/23/16 05:58PM
  Re: Urban Express 83 Wheel/Forks/Shocks Upgrade HelpRe: alex ganz alex ganz 10/22/18 05:19PM
