Yea thanks, I was a tradesman for 18 years til one day I pretty much dove head first into the deep end of an empty swimming pool. It's a wonder I can even move at all. That was the end of thaT. The guy at the school said, make sure your shit at home is as nice as the things u are building at work for the customer. Hunh..
The chain tensioning plastic guide has a thin spring. Seems kinda weak. I found a similar one that's a little thicker wire and bent it to match the stock spring then layed it up in there.
There was some kind of lever doodad on the pin. That piece slid off into the trash can. The spacer, washer and that other piece over the springs will be tacked together in there before I close it up.
I started hacking shit on the other side too
