A few more things I'm working on.
RdRd Pretty cool the stator side case needs metal filler, I can zip that off easy. The drive side is close, I'll back it up with Jb and deck it off flat. It's a marshmallossi 68cc kit with a Solo head. Nice and beasty! This should be fun. Ha!
I put new brake pads on the back. Cut diagonal kerfs and tapered the ends of the pads. An old Deezy explanation, go in about 3/4" from the end of the pad and taper that out, back to the end about 1/16" deep to make the center of the pad grip the hub. Or something like that to refresh an old set or tune a new set.
Here's the clutch bell slightly modified with holes drilled in it.
I weighed the hobbit clutch and a bell, it was about 40g lighter than this express clutch and bell. Unbelievable how heavy the starter arms are here. i want to have some fun comparing the starter arms weight from these other dudes. Its insane overkill! : )
