Magnum exhaust gasket
Got a major exhaust lead where the pipe clamps onto the header. Tried tightening the bolt but it didn't help. Looks like there is supposed to be a gasket there (#25 in the pic). I couldn't find it anywhere online, or much info on it. Anybody have an alternative?
Re: Magnum exhaust gasket
MPB Andyrew /
Aww sheeaattt meant to post to repair
Cut a piece of aluminum soda can and wrap it around the header a few times.
Bad Cadillac™ /
Dude, I have the same issue on my XK I just picked up a few months ago!
I too wonder and was going to cut a thin piece of aluminum roof flashing and slide it in there and around the header pipe. Then tighten the clamp.
However if there is the proper gasket out there, I'd get it instead.
I think that was an asbestos gasket. I have some new old stock ones but they crack if you try to bend them. You're gonna have to jury rig something up to seal that leak.
Smiley Vyrus /
Heavy gage aluminum foil has worked for me plenty of times.
I've just cut one out of regular gasket sheet stock (Treats or automotive store).
Works great, zero leakage.
MPB Andyrew /
Ok cool. So just whatever exhaust gasket material I can find, cut a rectangle out and then wrap it around where it clamps to the header? Seems easy enough.
And it goes in between the header and the chamber and not between the chamber and the clamp correct? (edited)
Bad Cadillac™ /
Just sealed mine up using aluminum roof flashing like I mentioned above. It was a tight fit so whatever you use you might want to use something made of metal because paper will just get shredded trying to put it back together.
Thats funny my Pinto I just picked up is also missing the gasket.
It's nice having an unmolested original for a perfect pattern.
> an alternative?
You didn't try very hard.
When looking for antique parts you have to think outside the box.
Thanks Larry for the warning as this one will never be used for anything other than a template.
ebay
(edited)
might try the aluminum gasket as described above and some copper exhaust seal paste if it's that bad
> bad
Actually I'm thinking copper or aluminum sheet or some rolled gasket material will work just fine. Just trace it off and cut it out. Pretty simple.
wasn't talking at you
Who cares????
Good luck with the deminsions. (edited)
Bad Cadillac™ /
Nice, I should do the same. (edited)
MPB Andyrew /
20 bucks for that thing? Seems a little steep. I'll hit the hardware store this weekend and see what they a have. Could you hook me up with some dims?
> dims?
I would be happy to.
Give me a few I stepped out of the building.
i cant believe this is still going.
cut open a beer can, wrap it around the pipe. crank it down done.
lol
Sorry forgot a couple dems.
can you place a quarter in the pix? so we can see the size of this mavel of engineering?
The tab is to prevent a leak at the seam and yes there was some thought given to it.
If you prefer beer cans or duct tape, then by all means don't let me stop ya. (edited)
oh...... i get it now
whats it made from?
MPB Andyrew /
Excellent thanks dude, you are the man!
A cut up beer can just wouldn't do my stocker MKII justice.
I forgot the thickness.
Sorry was running errands before work.
Will get it tonight.
1mm thick
Bad Cadillac™ /
1 MM was way too thick for my pipe. Unless I wanted to expand the pipe end to accommodate something thicker but I did not want to go the route and possibly cause another isdue or the clamp then not seal it again.
Just my two cents on my pipe.
