Got this with our last treats order for my friend's M1 build and went to check the stator fitment and the plate will not seat within the tabs that hold the stock stator plate in place. We were able to get the plate to balance on top of the tabs (just barely) and still be able to bolt it down but that didn't seem right.
Ended up grinding the inner faces of the retaining posts and were able to get it to fit inside nicely. Forgot to get a pic of it seated fully...Anyone else had this poblem?
Also, when the flywheel is installed on the crankshaft, it is impossible to adjust the stator plate left and right because the OD of the mini-rotor covers up the stator mounting screws. We can really only adjust the stator and and tighten it down when the flywheel is off. Is this right? I can adjust the hpi stator plate (red version) on my puch while the flywheel is installed.
