Re: MAGNOMOS
i have a few different seat ideas.. but that's a project for later on.
for now i need to find myself the cdi coil and cdi ignition box, and also an ac 12v regulator so i can have lights on the thing.
it's pretty much my only "legal" bike right now and i can't even ride it!
Re: MAGNOMOS
I like the seat a lot
Re: MAGNOMOS
That's one tired Rhino.
Re: MAGNOMOS
colby, can i send you emails? i have a question or two for you
Re: MAGNOMOS
its america, free country, thats why i love it, and you should too
Re: MAGNOMOS
just call me Canis Dirus /
that looks amazing. nice ped.
Re: MAGNOMOS
thanks, i can't wait to have the rear end figured out and the motor running proper! it'll be the fastes 50cc magnum ever! maybe? probably not.. but it will be neat!
Re: MAGNOMOS
Maitlanf Of the Loin /
I need to start learning how to port the magnum cylinder I have.
my franken beast magnum i just put together looks a little worse than yours hahahha
Re: MAGNOMOS
every magnum ever looks worse than magnomos, duh!
Re: MAGNOMOS
it is pretty sexy
but mine looks beat up in a "hey i dont think we should really ride this because it may fall apart" kinda way.
Re: MAGNOMOS
That's a stock motor? Damn, it's fast.
Of course, you weigh like what, 90 pounds? ;)
Re: MAGNOMOS
hey man can you post some up close pics of the engine mounts? im thinking about doing this on my trike.
Re: MAGNOMOS
dean is mopeder of the year
Re: MAGNOMOS
harold, i destroyed my digi cam, but i'm going to order a new one today, so in a couple days i will. or i might find someone i can borrow one from. also, i thought you sold your trike?
lol @ mopeder of the year.. i thought everyone would be all mad at me for cutting up a magnum to put on a tomos!
Re: MAGNOMOS
also, apparently joeyo forgot to log out on my computer, so i'm going to go make his profile awesome.
Re: MAGNOMOS
anyway, joey's last two posts here were me.
Re: MAGNOMOS
ahahaha.
yeah i did sell my Tri Rad. god that was stupid. i started making a custom trike myself. no slip differential this time though =(
originally i was thinking of putting a sachs madass engine on it. not sure if i still want to though
Re: MAGNOMOS
that thing deff needs pedals
Re: MAGNOMOS
yeah thats what im saying. i have an a3sp tomos motor already. but im thinking of picking up and a35 with CDI to put on here. the trike section is off a tomos trike, so the gearing ratios would match up too and make it a lot easier on me.
Re: MAGNOMOS
gearing ration is a big deal with tomos motors, it's one of the biggest problems i'm having with mine.
i say you put an a55 on there! no reeds, but those things are so freaking fast when stock!
"am on my tryke, jakin ur thred"
Re: MAGNOMOS
Bryan and I discussed this the other night, and decided that you are mopeder of the Year.
This is just one of the retarded projects I got to witness as his roommate in Seattle.
Dean had a vespa bravo with a cimatti gas tank and the frame cut down to about 10lbs. It rocked wheelies and 42mph.
He cracked the subframe and transferred the entire deal over to a tiny ciao with the words "fabulous" written in rhinestones on the gas tank.
Re: MAGNOMOS
haha you guys are silly. <3
and eric, i fixed a couple mobys at the shop yeseterday..
i kind of want one.
Re: MAGNOMOS
Harold.
The two bolts on either side match up pattern wise from puch to tomos. But you gotta do a slight bit of fabrication i.e. cut some material away for tomos to fit on puch. But if you have the swiss cheese frame that can be sketchy because then there isn't enough material left in my opinion if your going to use a tomos motor without kick start. (because you put all your weight and torque on the motor via the pedals) and since thats the case with mine I just had brian add material and now its beefy as fuck.
Right now you can bolt up either tomos or puch without any qualms...
The only snag I ran into was the chain scrapping slightly on the frame but thats fixed now with a slight bit tweaking.
p.s. this is an idea I got from Bainsworth in Richmond. I saw his bike and liked it so much it inspired me to build one similar. He uses a rigid freespirit though and mine obviously will be a complete rigid pinto.
Re: MAGNOMOS
ps I know its rough right now welding wise. but its gonna be all clean as hell with bondo and hella sanding.
Re: MAGNOMOS
With mine I used 2 top mounts and used the factory bottom mount. They are just steel plate but they are like 10x stronger than stock.
Re: MAGNOMOS
wow thanks for the info guys. travis your swingos is gonna be sick man. yeah im more than capable of welding some support it. good to know it just bolts in though. makes shit a lot easier.
Re: MAGNOMOS
you've got a long way to go if you want the fastest 50cc magnum
Re: MAGNOMOS
i ment in seattle, duh!
Re: MAGNOMOS
Brian Mikami /
That is kool! Good luck.
Re: MAGNOMOS
like i said, theres two people i can think of you need to beat now
and the word on the street is that scoobs just got a magnum tank
so
i am thinking,
4 bike magnum race
