Re: Is the Motobecane 50v a nice bike?
Stephen Keller /
They were assembled with great attention to detail, each fitting (stock) has the appropriate spacers lock washers etc, when people start losing them or hack them is when they have issues. Not had my 50v apart much, but took my "7" partially apart last summer and was amazed at all the little pieces parts, just have to lay them out in order they were removed, (I have a bad memory) but if you put them back as they came apart it will be fine, a good grease gun is needed for the variator and pedal shaft, also leave the pedal/engine switch alone!!! The internals of the driven pulley can rust up, and if you get it out of engine mode it can be a real bitch to get back. If you must pedal the bike push the engine back and slip the belt, very easy, but you don't want to pedal one other than to start it anyway, too heavy and geared too low, you can walk it faster.
  Is the Motobecane 50v a nice bike?Topic by: Paul H Paul H 12/21/15 09:26PM
  Re: Is the Motobecane 50v a nice bike?Re: Andrew Squiggman Andrew Squiggman 12/21/15 09:39PM
  Re: Is the Motobecane 50v a nice bike?Re: Paul H Paul H 12/21/15 09:43PM
  Re: Is the Motobecane 50v a nice bike?Re: Andrew Squiggman Andrew Squiggman 12/21/15 09:49PM
  Re: Is the Motobecane 50v a nice bike?Re: Paul H Paul H 12/21/15 09:54PM
  Re: Is the Motobecane 50v a nice bike?Re: Allan RJH Allan RJH 12/21/15 09:57PM
  Re: Is the Motobecane 50v a nice bike?Re: Paul H Paul H 12/21/15 09:59PM
  Re: Is the Motobecane 50v a nice bike?Re: Stephen Keller Stephen Keller 12/21/15 10:08PM
  Re: Is the Motobecane 50v a nice bike?Re: - rwc - - rwc - 12/21/15 10:11PM
  Re: Is the Motobecane 50v a nice bike?Re: Paul H Paul H 12/21/15 10:16PM
  Re: Is the Motobecane 50v a nice bike?Re: Stephen Keller Stephen Keller 12/21/15 10:23PM
  Re: Is the Motobecane 50v a nice bike?Re: Paul H Paul H 12/21/15 10:27PM
  Re: Is the Motobecane 50v a nice bike?Re: - rwc - - rwc - 12/21/15 10:29PM
  Re: Is the Motobecane 50v a nice bike?Re: Paul H Paul H 12/21/15 10:36PM
  Re: Is the Motobecane 50v a nice bike?Re: Stephen Keller Stephen Keller 12/21/15 10:37PM
  Re: Is the Motobecane 50v a nice bike?Re: The Real Mike D The Real Mike D 12/21/15 10:32PM
  Re: Is the Motobecane 50v a nice bike?Re: Paul H Paul H 12/21/15 10:35PM
  Re: Is the Motobecane 50v a nice bike?Re: Andrew Squiggman Andrew Squiggman 12/21/15 11:08PM
  Re: Is the Motobecane 50v a nice bike?Re: Stephen Keller Stephen Keller 12/21/15 10:49PM
  Re: Is the Motobecane 50v a nice bike?Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 12/21/15 10:53PM
  Re: Is the Motobecane 50v a nice bike?Re: Paul H Paul H 12/21/15 11:07PM
  Re: Is the Motobecane 50v a nice bike?Re: Stephen Keller Stephen Keller 12/21/15 11:06PM
  Re: Is the Motobecane 50v a nice bike?Re: Max Johnson Max Johnson 12/21/15 11:14PM
  Re: Is the Motobecane 50v a nice bike?Re: Stephen Keller Stephen Keller 12/21/15 11:16PM
  Re: Is the Motobecane 50v a nice bike?Re: Max Johnson Max Johnson 12/22/15 12:47AM
  Re: Is the Motobecane 50v a nice bike?Re: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 12/22/15 08:20AM
  Re: Is the Motobecane 50v a nice bike?Re: NEMA Victor (3 Knees Down) NEMA Victor (3 Knees Down) 12/22/15 04:08PM
  Re: Is the Motobecane 50v a nice bike?Re: jeffrey Suarez jeffrey Suarez 12/22/15 12:14AM
  Re: Is the Motobecane 50v a nice bike?Re: Hells Satans Sleepydog Hells Satans Sleepydog 12/22/15 01:13AM
  Re: Is the Motobecane 50v a nice bike?Re: Jimmy Cincinnati Jimmy Cincinnati 12/22/15 09:03AM
  Re: Is the Motobecane 50v a nice bike?Re: Matt Madden Matt Madden 12/22/15 09:50AM
  Re: Is the Motobecane 50v a nice bike?Re: Badboy Brandon Badboy Brandon 12/22/15 12:18PM
  Re: Is the Motobecane 50v a nice bike?Re: Dan (LandLordsMG/PSVMC) Dan (LandLordsMG/PSVMC) 12/22/15 03:13PM
  Motobecane 50v perpare for a love/hate relationship!Re: Rebel Moby Rebel Moby 12/24/15 04:34PM
  Re: Is the Motobecane 50v a nice bike?Re: Max Johnson Max Johnson 12/24/15 05:41PM
  Re: Is the Motobecane 50v a nice bike?Re: Lauri V Lauri V 12/24/15 07:55PM
  Re: Is the Motobecane 50v a nice bike?Re: Kiel the Canuck Kiel the Canuck 12/25/15 07:49PM
  Re: Is the Motobecane 50v a nice bike?Re: ---------------- LaZer ------------* ---------------- LaZer ------------* 12/27/15 11:20PM
