Re: piaggio ciao, fixing
bruce /
The Ciao has a small lever on the left hand grip. this is a Compression release.If you pull it in it opens a small valve in the cylinder head and makes it easier to peddle. After you get going a little bit you let go of the lever and it closes this valve and the engine should start.Maybe the valve is stuck open. Trace the cable to the head and see if it is opening and closing. Supervespashop has all parts and a manual $15 u.s. Phone Fabio 619 574 1818 in San Diego. Fuel is 50:1 or 2and a half oz. of 2 stroke oil to a gallon of gas. This bike is common and a lot of army people can help you , just post your questions.bruce
  piaggio ciao, fixingTopic by: dan dan 06/10/02 08:56PM
  Re: piaggio ciao, fixingRe: bruce bruce 06/10/02 09:12PM
  Re: piaggio ciao, fixingRe: bruce bruce 06/10/02 09:15PM
  Re: piaggio ciao, fixingRe: bruce bruce 06/10/02 09:22PM
  Re: piaggio ciao, fixingRe: dan dan 06/11/02 10:52AM
  Re: piaggio ciao, fixingRe: bruce bruce 06/11/02 07:44PM
