Scott Truong Wrote:
> Jimmy Cincinnati Wrote:
> > I ran into this issue today with an early
> 2000's
> > tomos. I honest to go dont think it is stamped
> on
> > the frame anymore, it just gets to foil tags. I
> > know in the 80's it was stamped above the
> engine
> > on the frame mounts.
> > Your motor will have a vin however engine vins
> do
> > not always match the frame serial even from the
> > factory. But sometimes they do. That is located
> > behind your carb understand the frame on a
> raised
> > section of your engine cases.
> Cool, I'll check if I can find the engine numbers
> and if they match the part of the VIN I do have
> that wasn't completely rubbed off.
Doesn't seem like my engine VIN matches frame VIN:/....
