Jimmy Cincinnati Wrote:
> I ran into this issue today with an early 2000's
> tomos. I honest to go dont think it is stamped on
> the frame anymore, it just gets to foil tags. I
> know in the 80's it was stamped above the engine
> on the frame mounts.
> Your motor will have a vin however engine vins do
> not always match the frame serial even from the
> factory. But sometimes they do. That is located
> behind your carb understand the frame on a raised
> section of your engine cases.
Cool, I'll check if I can find the engine numbers and if they match the part of the VIN I do have that wasn't completely rubbed off.
