can someone tell me a good minarelli set up?
merlin311 /
i don't want to go out and spend 300-400 in parts then none of them work together.
i want to stay 50cc because of dependability.but anything else ill mod the hell out of.
this is what miguel suggested
get a larger carburetor
get a larger main jet
get a larger manifold
get a larger front tooth sprocket
get a larger (or less restricted) airbox
get a performance exhaust
no names etc.im not familiar to these really only things i've done before we're bored .40 over briggs engine runnin on alcohol
so if someone knows a hot setup tell me ill be running sava slicks on it too it'll be pure street
Re: can someone tell me a good minarelli set up?
merlin311 /
heres what im thinkin so far
15mm carb dellorto
11 tooth front sprocket
sava slicks
powerfilter(or a k&n)
fully tuned exhaust
and derestricting it
a rpm limiter variable(so if i get stopped by cops)(usual thing in this town
i dunno though ill see what everyone else thinks
i'm not sure what some of the things you suggested for yourself would do (e.g. rpm limiter or sava slicks). but here's what's on my minarelli ...
12-tooth front sprocket
dellorto 15.15mm carb w/ #55 jet
polini performance exhaust
fully derestricted airbox
merlin311 /
whats is the speed your getting?
i'm not sure on my top speed ... but it's at least 35mph. but ... w/ such a large front tooth, my acceleration is piss poor. i'm thinking of dropping down to 11-tooth front sprocket.
merlin311 /
yea thats why i wanted an 11 tooth cuz getting any further u have no accelleration.have you thought about cutting the red wire on your cdi and installing a rev limiter?because performance exhausts peak out at 1500-2000rpm above stock.
you can get a rev limiter from 50cc.nl for 23 bux or so.
merlin311 /
newest idea...
70cc kit
tuned exhaust
21mm carb and doppler intake
it all comes out to like 270 or so us from 50cc.nl
this is the main jest of it other then transmission mods(which alil may have to be done or im going to have like no powerband)
merlin311 /
one more? anyone know about what size jet im going to need on that last set up?
All Those Mods for Meager Results?
Miguel,
I haven't done any mods to my Cimatti/Minarelli yet and I'm getting 30 mph. It seems as though you've gone to a lot of trouble to get only five mph, especially including the steeper front sprocket.
I'm working on getting the exhaust and new carb, but now I'm wondering if it's worth the cost and bother to get only 2-3 mph (I wouldn't do the sprocket change.)
JD
P.S. How fast was your moped before the modifications, and how much do you weigh (if it's not too personal)?
Re: All Those Mods for Meager Results?
I am sure miguel wouldn't mind that you ask how much he weighs...I am going to guess a buck o five. :)
