Re: bottom chain sagging any ideas
Marc Friedman /
Don't knew what bike buuut loosen rear wheel/axle and carefully pass the chain counterclockwise over one link of chain on the rear sprocket and then tighten the axle after tensioning the chain. But if instead you are a troll then I suggest you do what bilbo bagging did and do this just before sunrise so that in first light you turn into stone.
