bottom chain sagging any ideas
Hey good folks in moped world so seems like my bottom chain is sagging but tight on the top any ideas thanks much !!!
Re: bottom chain sagging any ideas
no one of covfefe /
try tightening the bottom of the chain and see if the top sags?
Don't knew what bike buuut loosen rear wheel/axle and carefully pass the chain counterclockwise over one link of chain on the rear sprocket and then tighten the axle after tensioning the chain. But if instead you are a troll then I suggest you do what bilbo bagging did and do this just before sunrise so that in first light you turn into stone.
Re: How many Croatians does it take?
little croatia /
Marc that actually solved it Thanks much ...
Tighten the bottom, and leave the top like it is.
My bottom is sagging a little too...
My Cat just had puppy's ...who in turn chase themselves up trees...(PS) When was the last time you oiled said chain ? (edited)
