Re: SOLO MOPED: WTF IS IT? BATA-PUGO-MOBY??
Andrew Squiggman /
Odyssey is a brand name for US mopeds made in Germany by Solo. There are two transmission versions, one speed (ein gang) and two speed (zwei gang), and four speed versions:
Type 236: 8.3 CR, 1.45hp @3250, 2 transfer ports, air cooled
Type 237: 7.5 CR, 2.1 hp @5000, 2 transfer ports, air cooled
Type 254: 8.3 CR, 1.75hp @4000, 3 transfer ports, coolant in head
Type 255: 10.0 CR, 2.6 hp @5000, 3 transfer ports, coolant in head
254/255’s have a different clutch, crank, left seal, from the 236/237.
All versions have these specifications: 38 x 42 bore and stroke, aluminum cylinder with steel sleeve, piston clearance 0.0016″ to 0.0024″, piston rings 38 x 1.5 with FG gap style, ring gap 0.008 – 0.020″, 10mm Bing carburetor 1/10/112 with jet #58, Bosch magneto 0212 005 001, point gap 0.014 – 0.018″. Link to Project Moped Manual for the Odyssey Service Manual, for more info.
