Re: Advice needed: ZA50 kit piston skirt hits the crank case at btdc
Garrett Bell /
Reviving this thread,
Just got the malossi kit for my ZA50 and the skirt hits as well just the way the picture above shows. Was curious what the best way to trim the skirt would be?
I dont have any major machining equipment, was thinking maybe a chop saw with metal bit, or sanding on a flat surface or anything that MA can help brainstorm.
Attached are some pics of the piston, was also curious after the skirt is trimmed, do i need to modify the edges that are trimmed to mimic the angle inside the piston?
Any help is greatly appreciated, thanks!
  Advice needed: ZA50 kit piston skirt hits the crank case at btdcTopic by: Dmitry K. Dmitry K. 03/31/15 10:23AM
  Re: Advice needed: ZA50 kit piston skirt hits the crank case at btdcRe: Adam Klags MPG Adam Klags MPG 03/31/15 10:43AM
  Re: Advice needed: ZA50 kit piston skirt hits the crank case at btdcRe: MPB Dylan MPB Dylan 03/31/15 10:53AM
  Re: Advice needed: ZA50 kit piston skirt hits the crank case at btdcRe: will warn will warn 03/31/15 12:12PM
  Re: Advice needed: ZA50 kit piston skirt hits the crank case at btdcRe: Dmitry K. Dmitry K. 03/31/15 12:37PM
  Re: Advice needed: ZA50 kit piston skirt hits the crank case at btdcRe: Bob Selby Bob Selby 03/31/15 02:33PM
  Re: Advice needed: ZA50 kit piston skirt hits the crank case at btdcRe: Daniel '' Daniel '' 03/31/15 03:40PM
  Re: Advice needed: ZA50 kit piston skirt hits the crank case at btdcRe: Garrett Bell Garrett Bell 01/03/18 06:59PM
  Re: Advice needed: ZA50 kit piston skirt hits the crank case at btdcRe: Dmitry K. Dmitry K. 01/03/18 09:09PM
  Re: Advice needed: ZA50 kit piston skirt hits the crank case at btdcRe: Baron Von Hamilton Baron Von Hamilton 01/03/18 09:39PM
  Re: Advice needed: ZA50 kit piston skirt hits the crank case at btdcRe: Garrett Bell Garrett Bell 01/04/18 12:15PM
  Re: Advice needed: ZA50 kit piston skirt hits the crank case at btdcRe: Daniel '' Daniel '' 01/04/18 01:58PM
  Re: Advice needed: ZA50 kit piston skirt hits the crank case at btdcRe: Baron Von Hamilton Baron Von Hamilton 01/04/18 06:22PM
  Re: Advice needed: ZA50 kit piston skirt hits the crank case at btdcRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 01/04/18 02:04PM
  Re: Advice needed: ZA50 kit piston skirt hits the crank case at btdcRe: Thomas Smith Thomas Smith 01/04/18 02:58PM
  Re: Advice needed: ZA50 kit piston skirt hits the crank case at btdcRe: Born to be WillD Born to be WillD 01/04/18 03:45PM
Click here to login.
