Re: The most EXPENSIVE moped exhaust ever: Build thread
will warn /
weldwizard Jake Wrote:
> RADIUM CITY JO$HUA Wrote:
> > Side questions, what weld machine do you have
> that
> > handles all of these crazy alloys? What hood do
> > you use?
> I use a Jackson Halo hood with a NexGen
> auto-darkening lens. The Halo hood is light and
> comfortable. Looking through most lenses has a
> green color to them, the nexgen lens has an amber
> color that looks better and gives awesome
> clarity.
> These alloys don't really require any kind of
> special machine. I did all of this work with a TIG
> machine on DC-, a variable pedal, with the
> amperage set at 70 and no special pulse settings,
> just straight current. So any machine that can do
> that (pretty much any TIG machine in existence)
> could theoretically make these welds. Of course,
> some older machines and a lot of newer machines
> will just generally work better than others and
> thus make things a bit smoother and easier to do.
> What alloys like this and pretty much any material
> requires for TIG welding is extremely clean work,
> that is always well gas covered. Abrasive clean
> all the surfaces to be welded, inside and out,
> scotch brite pads work good for that. Wipe down
> the area to be welded and your filler rod with
> acetone or other cleaner that will remove dirt and
> oil but evaporates and leaves no residue. With
> materials like Stainless, Inconel, and Titanium,
> gas coverage is extremely important. Always use a
> gas lens on the torch, seriously, if you are not
> using gas lenses you are really missing out. They
> also must be back purged, that means there must be
> gas on the back side of the weld too, if you dont
> do this, you are majorly fucking up the metal and
> may as well just make it out of mild steel.
> I'm gonna stop there because I can really go on
> and on about this. Welding and fabrication is my
> passion, sometimes I cant shut up about it.
you ever see Brown Dog?
https://www.flickr.com/photos/browndogwelding/sets/72157626965718671/
so you just plug one end and back purge the other? no use of inert chamber or shit like that?
  The most EXPENSIVE moped exhaust ever: Build threadTopic by: weldwizard Jake weldwizard Jake 02/21/15 07:27PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Alex Gween Blastard Alex Gween Blastard 02/21/15 07:45PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Cameron Acuff Cameron Acuff 02/21/15 07:56PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: RADIUM CITY JO$HUA RADIUM CITY JO$HUA 02/21/15 07:59PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Andrew Squiggman Andrew Squiggman 02/21/15 08:05PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/22/15 12:28AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Andrew Squiggman Andrew Squiggman 02/22/15 12:34AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: T y l e r T y l e r 02/22/15 01:28AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: simon thokaar simon thokaar 02/22/15 02:10AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Nate Dood Nate Dood 02/21/15 08:01PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 02/21/15 08:20PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 02/21/15 08:20PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Kiel the Canuck Kiel the Canuck 02/21/15 08:20PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: kim jensen kim jensen 02/21/15 08:28PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Matt Spriedejs Matt Spriedejs 02/21/15 08:39PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Mai ze Mai ze 02/21/15 10:40PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Andrew G Andrew G 02/21/15 08:39PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: I Am I Am 02/21/15 09:34PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: «tyler » «tyler » 02/21/15 11:18PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: jeffrey Suarez jeffrey Suarez 02/21/15 09:40PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: † CH∆D † † CH∆D † 02/21/15 09:45PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: † CH∆D † † CH∆D † 02/21/15 10:00PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: T y l e r T y l e r 02/21/15 10:08PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Josiah McCoy Josiah McCoy 02/21/15 11:09PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: will warn will warn 02/21/15 11:32PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Dan Ott Dan Ott 02/21/15 11:43PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Sir Christopher BLKBLK Sir Christopher BLKBLK 02/21/15 11:48PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Jesse Stephenson Jesse Stephenson 02/21/15 11:56PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Brandon Love Brandon Love 02/22/15 12:15AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: David Daughters David Daughters 02/22/15 12:40AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: will warn will warn 02/22/15 01:21AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Tate G Tate G 02/22/15 02:17AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 02/22/15 02:20AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Chip _ Chip _ 02/22/15 07:23AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: barney gierer barney gierer 02/22/15 10:09AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Dave & Bummerzz Dave & Bummerzz 02/22/15 11:53AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/22/15 12:21PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Mai ze Mai ze 02/22/15 12:30PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Nathan Kiehn Nathan Kiehn 02/22/15 02:41PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Mai ze Mai ze 02/22/15 02:46PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Nathan Kiehn Nathan Kiehn 02/22/15 03:31PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: I Am I Am 02/22/15 04:53PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 02/22/15 05:58PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: scrot rash scrot rash 02/22/15 12:34PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Jesse Stephenson Jesse Stephenson 02/22/15 01:26PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/22/15 02:33PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/22/15 03:30PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 02/22/15 03:40PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/22/15 04:38PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: will warn will warn 02/22/15 09:46PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Jesse Stephenson Jesse Stephenson 02/22/15 10:14PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Nathan Kiehn Nathan Kiehn 02/22/15 04:54PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/22/15 05:14PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/22/15 05:18PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Jason Jason Bobason Jason Jason Bobason 02/22/15 06:56PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Brandon LSLB Brandon LSLB 02/22/15 07:37PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Gromosaurus Rex - Brad Pitt Gromosaurus Rex - Brad Pitt 02/23/15 11:33AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Miss Tammiecat~ Miss Tammiecat~ 02/23/15 11:48AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Born to be WillD Born to be WillD 02/23/15 12:12PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Moby Dick Moby Dick 02/23/15 03:55PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Max Johnson Max Johnson 02/23/15 09:41PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: arty party arty party 02/24/15 01:14PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/23/15 10:17PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: †▲m †▲m †▲m †▲m 02/24/15 02:32PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Graham Motzing Graham Motzing 02/24/15 06:43PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: French Moby French Moby 01/09/19 05:17PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: alex . alex . 01/09/19 10:47PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Charles Cole (OFMC) Charles Cole (OFMC) 02/28/15 02:54PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/28/15 06:54PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: nick s nick s 03/02/15 09:29AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 05/23/15 02:43AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Dan Ott Dan Ott 05/23/15 02:48PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: timothy rendall timothy rendall 09/21/15 05:03PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 05/23/15 04:38AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Honest Mike Honest Mike 05/23/15 07:01AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: - schmiddy - schmiddy 05/24/15 12:25PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 05/24/15 12:53PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Tate The Great Tate The Great 05/24/15 01:39PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Derek Vanasse Derek Vanasse 07/16/15 01:44PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Ian T Ian T 07/17/15 02:21PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Mr. Duncan Mr. Duncan 07/19/15 05:27PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Shelby O'Dell Shelby O'Dell 09/20/15 01:56PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Private Ryan Private Ryan 09/20/15 06:19PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Ninja . Ninja . 09/21/15 06:22PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Mai ze Mai ze 09/22/15 09:03AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: A S H A S H 09/22/15 09:10AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 09/22/15 11:07PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: scrot rash scrot rash 09/23/15 08:50AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: scrot rash scrot rash 09/23/15 09:00AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Mai ze Mai ze 09/23/15 08:59AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: T y l e r T y l e r 09/23/15 01:33PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 09/24/15 12:31AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Corporate Image Corporate Image 09/24/15 03:07PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 11/11/15 11:22PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 01/08/19 12:04AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 01/08/19 12:08AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 01/08/19 12:12AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 01/08/19 12:16AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 01/08/19 12:28AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: EH FCC of the QCB EH FCC of the QCB 01/08/19 06:22AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: scrot rash scrot rash 01/08/19 09:36AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: MPB Andyrew MPB Andyrew 01/08/19 10:13AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Captain Janeway Captain Janeway 01/08/19 10:19AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Jason Thompson Jason Thompson 07/01/19 03:32AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Shane Rickert Shane Rickert 01/08/19 08:54AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Bas Autowas Bas Autowas 01/08/19 09:03AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Dirty30 Dillon Dirty30 Dillon 01/08/19 10:46AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: MOPITT no nips Al MOPITT no nips Al 01/08/19 10:14AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: LSLB Lou 😤 LSLB Lou 😤 01/10/19 09:46PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Jaxon Andrews Jaxon Andrews 07/02/19 08:45AM
