Re: The most EXPENSIVE moped exhaust ever: Build thread
weldwizard Jake /
RADIUM CITY JO$HUA Wrote:
> Side questions, what weld machine do you have that
> handles all of these crazy alloys? What hood do
> you use?
I use a Jackson Halo hood with a NexGen auto-darkening lens. The Halo hood is light and comfortable. Looking through most lenses has a green color to them, the nexgen lens has an amber color that looks better and gives awesome clarity.
These alloys don't really require any kind of special machine. I did all of this work with a TIG machine on DC-, a variable pedal, with the amperage set at 70 and no special pulse settings, just straight current. So any machine that can do that (pretty much any TIG machine in existence) could theoretically make these welds. Of course, some older machines and a lot of newer machines will just generally work better than others and thus make things a bit smoother and easier to do.
What alloys like this and pretty much any material requires for TIG welding is extremely clean work, that is always well gas covered. Abrasive clean all the surfaces to be welded, inside and out, scotch brite pads work good for that. Wipe down the area to be welded and your filler rod with acetone or other cleaner that will remove dirt and oil but evaporates and leaves no residue. With materials like Stainless, Inconel, and Titanium, gas coverage is extremely important. Always use a gas lens on the torch, seriously, if you are not using gas lenses you are really missing out. They also must be back purged, that means there must be gas on the back side of the weld too, if you dont do this, you are majorly fucking up the metal and may as well just make it out of mild steel.
I'm gonna stop there because I can really go on and on about this. Welding and fabrication is my passion, sometimes I cant shut up about it.
  The most EXPENSIVE moped exhaust ever: Build threadTopic by: weldwizard Jake weldwizard Jake 02/21/15 07:27PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Alex Gween Blastard Alex Gween Blastard 02/21/15 07:45PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Cameron Acuff Cameron Acuff 02/21/15 07:56PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: RADIUM CITY JO$HUA RADIUM CITY JO$HUA 02/21/15 07:59PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Andrew Squiggman Andrew Squiggman 02/21/15 08:05PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/22/15 12:28AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Andrew Squiggman Andrew Squiggman 02/22/15 12:34AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: T y l e r T y l e r 02/22/15 01:28AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: simon thokaar simon thokaar 02/22/15 02:10AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Nate Dood Nate Dood 02/21/15 08:01PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 02/21/15 08:20PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 02/21/15 08:20PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Kiel the Canuck Kiel the Canuck 02/21/15 08:20PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: kim jensen kim jensen 02/21/15 08:28PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Matt Spriedejs Matt Spriedejs 02/21/15 08:39PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Mai ze Mai ze 02/21/15 10:40PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Andrew G Andrew G 02/21/15 08:39PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: I Am I Am 02/21/15 09:34PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: «tyler » «tyler » 02/21/15 11:18PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: jeffrey Suarez jeffrey Suarez 02/21/15 09:40PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: † CH∆D † † CH∆D † 02/21/15 09:45PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: † CH∆D † † CH∆D † 02/21/15 10:00PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: T y l e r T y l e r 02/21/15 10:08PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Josiah McCoy Josiah McCoy 02/21/15 11:09PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: will warn will warn 02/21/15 11:32PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Dan Ott Dan Ott 02/21/15 11:43PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Sir Christopher BLKBLK Sir Christopher BLKBLK 02/21/15 11:48PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Jesse Stephenson Jesse Stephenson 02/21/15 11:56PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Brandon Love Brandon Love 02/22/15 12:15AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: David Daughters David Daughters 02/22/15 12:40AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: will warn will warn 02/22/15 01:21AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Tate G Tate G 02/22/15 02:17AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 02/22/15 02:20AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Chip _ Chip _ 02/22/15 07:23AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: barney gierer barney gierer 02/22/15 10:09AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Dave & Bummerzz Dave & Bummerzz 02/22/15 11:53AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/22/15 12:21PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Mai ze Mai ze 02/22/15 12:30PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Nathan Kiehn Nathan Kiehn 02/22/15 02:41PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Mai ze Mai ze 02/22/15 02:46PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Nathan Kiehn Nathan Kiehn 02/22/15 03:31PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: I Am I Am 02/22/15 04:53PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 02/22/15 05:58PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: scrot rash scrot rash 02/22/15 12:34PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Jesse Stephenson Jesse Stephenson 02/22/15 01:26PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/22/15 02:33PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/22/15 03:30PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 02/22/15 03:40PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/22/15 04:38PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: will warn will warn 02/22/15 09:46PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Jesse Stephenson Jesse Stephenson 02/22/15 10:14PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Nathan Kiehn Nathan Kiehn 02/22/15 04:54PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/22/15 05:14PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/22/15 05:18PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Jason Jason Bobason Jason Jason Bobason 02/22/15 06:56PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Brandon LSLB Brandon LSLB 02/22/15 07:37PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Gromosaurus Rex - Brad Pitt Gromosaurus Rex - Brad Pitt 02/23/15 11:33AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Miss Tammiecat~ Miss Tammiecat~ 02/23/15 11:48AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Born to be WillD Born to be WillD 02/23/15 12:12PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Moby Dick Moby Dick 02/23/15 03:55PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Max Johnson Max Johnson 02/23/15 09:41PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: arty party arty party 02/24/15 01:14PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/23/15 10:17PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: †▲m †▲m †▲m †▲m 02/24/15 02:32PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Graham Motzing Graham Motzing 02/24/15 06:43PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: French Moby French Moby 01/09/19 05:17PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: alex . alex . 01/09/19 10:47PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Charles Cole (OFMC) Charles Cole (OFMC) 02/28/15 02:54PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 02/28/15 06:54PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: nick s nick s 03/02/15 09:29AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 05/23/15 02:43AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Dan Ott Dan Ott 05/23/15 02:48PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: timothy rendall timothy rendall 09/21/15 05:03PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 05/23/15 04:38AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Honest Mike Honest Mike 05/23/15 07:01AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: - schmiddy - schmiddy 05/24/15 12:25PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 05/24/15 12:53PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Tate The Great Tate The Great 05/24/15 01:39PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Derek Vanasse Derek Vanasse 07/16/15 01:44PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Ian T Ian T 07/17/15 02:21PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Mr. Duncan Mr. Duncan 07/19/15 05:27PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Shelby O'Dell Shelby O'Dell 09/20/15 01:56PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Private Ryan Private Ryan 09/20/15 06:19PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Ninja . Ninja . 09/21/15 06:22PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Mai ze Mai ze 09/22/15 09:03AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: A S H A S H 09/22/15 09:10AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 09/22/15 11:07PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: scrot rash scrot rash 09/23/15 08:50AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: scrot rash scrot rash 09/23/15 09:00AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Mai ze Mai ze 09/23/15 08:59AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: T y l e r T y l e r 09/23/15 01:33PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 09/24/15 12:31AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Corporate Image Corporate Image 09/24/15 03:07PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 11/11/15 11:22PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 01/08/19 12:04AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 01/08/19 12:08AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 01/08/19 12:12AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 01/08/19 12:16AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: weldwizard Jake weldwizard Jake 01/08/19 12:28AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: EH FCC of the QCB EH FCC of the QCB 01/08/19 06:22AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: scrot rash scrot rash 01/08/19 09:36AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: MPB Andyrew MPB Andyrew 01/08/19 10:13AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Captain Janeway Captain Janeway 01/08/19 10:19AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Jason Thompson Jason Thompson 07/01/19 03:32AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Shane Rickert Shane Rickert 01/08/19 08:54AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Bas Autowas Bas Autowas 01/08/19 09:03AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Dirty30 Dillon Dirty30 Dillon 01/08/19 10:46AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: MOPITT no nips Al MOPITT no nips Al 01/08/19 10:14AM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: LSLB Lou 😤 LSLB Lou 😤 01/10/19 09:46PM
  Re: The most EXPENSIVE moped exhaust ever: Build threadRe: Jaxon Andrews Jaxon Andrews 07/02/19 08:45AM
