octane relates to knock resistance. the higher the octane the harder to ignite. it won't burn a piston head etc. you will actually loose power and mileage. if your ignition system isn't up to par as mine is, you'll blow a lot of it out the pipe. if you want a good additive, try marvel mystery oil.
