my chopper
flannelman /
getting closer to getting done with it i just got done with converting it to 12v with a car aternater it doesnt look that bad but does any one know were i can get a battery box cheap for a motorcycle battery
oh ya just if your wondering this is a moped
1978 honda expess with a milled head and port exhaust and intack
im getting 35mph now but it will probly drop when i finish it ill get pic for it when im finish with it
just to let every one know it does matter if you put gas atives in
i use heat in my gas tank to help with water in gas
and card cleaner to help with the tarishing
fred was wrong on that
ive been working on moped and motorcycle and cars most of my life
but he is right it wont help your perfomance any
and if you use to high of an octane you could burn your piston or worse ive done it its not fun
Re: my chopper
picture, please?
Re: my chopper
octane relates to knock resistance. the higher the octane the harder to ignite. it won't burn a piston head etc. you will actually loose power and mileage. if your ignition system isn't up to par as mine is, you'll blow a lot of it out the pipe. if you want a good additive, try marvel mystery oil.
