Re: timing
bruce /
Fred, The points assembly on a Ciao is fixed, no slots, and the pivot 'hinge' for the points, fits in an indentation so that it can not be repositioned. The points open when the cam lobe strikes the heel. With no adjustment of the heel then how can you change the time that the heel is struck by the cam lobe. If I set them the way that you say, will they still not open when the heel gets hit. I'm having trouble understanding how this setting can be changed by setting the points gap. Also, the Ciao flywheel can't be measured unless you remove the engine,it's buried under a cover and the frame. Anyone out there got a flywheel on a bench to measure. bruce
  timingTopic by: VespaCIAO VespaCIAO 06/01/02 02:50AM
  Re: timingRe: DOUGLS SCHOLL DOUGLS SCHOLL 06/01/02 07:32AM
  Re: timingRe: bruce bruce 06/01/02 01:20PM
  Re: timingRe: Chris Robertson Chris Robertson 06/01/02 04:54PM
  Re: timingRe: Fred Fred 06/01/02 06:25PM
  Re: timingRe: bruce bruce 06/01/02 07:46PM
  Re: timingRe: Fred Fred 06/01/02 10:54PM
  Re: timingRe: bruce bruce 06/02/02 12:02PM
  Re: timingRe: Fred Fred 06/02/02 09:55PM
  Re: timingRe: bruce bruce 06/02/02 10:54PM
  Re: timingRe: Fred Fred 06/02/02 11:14PM
  Re: timingRe: Ron Brown Ron Brown 06/03/02 11:39AM
  Re: timingRe: Chris Rice Chris Rice 06/02/02 11:23PM
  retardedRe: Fred Fred 06/02/02 11:32PM
