Re: timing
Fred /
Well Bruce... you can make your own marks on the flywheel.
First use a screwdriver in the spark plug hole... and get the piston at the top.
make a nice straight clear mark anywhere in plain sight on the flywheel.
Then... attach a wire coathanger under a bolt head somewhere near there.
Then... while the piston is at TDC... bend the coathanger till it lines up with the mark you made.
Next... measure your flywheel diameter... then tell me what it is... then I will give you a dimension to make another mark a set distance from the first one.
THEN... use an electrical meter and determine WHEN the points break... adjust the point gap till the points break when the second mark is lining up with the coathanger.
Done.
Also... if your points are mounted to a removable plate that is screwed to the motor (under the flywheel)... then it might be possible to slot those screw holes (if they are not already)... and rotate that plate to help you set the timing... (instead of relying on the point gap to set the timing).
  timingTopic by: VespaCIAO VespaCIAO 06/01/02 02:50AM
  Re: timingRe: DOUGLS SCHOLL DOUGLS SCHOLL 06/01/02 07:32AM
  Re: timingRe: bruce bruce 06/01/02 01:20PM
  Re: timingRe: Chris Robertson Chris Robertson 06/01/02 04:54PM
  Re: timingRe: Fred Fred 06/01/02 06:25PM
  Re: timingRe: bruce bruce 06/01/02 07:46PM
  Re: timingRe: Fred Fred 06/01/02 10:54PM
  Re: timingRe: bruce bruce 06/02/02 12:02PM
  Re: timingRe: Fred Fred 06/02/02 09:55PM
  Re: timingRe: bruce bruce 06/02/02 10:54PM
  Re: timingRe: Fred Fred 06/02/02 11:14PM
  Re: timingRe: Ron Brown Ron Brown 06/03/02 11:39AM
  Re: timingRe: Chris Rice Chris Rice 06/02/02 11:23PM
  retardedRe: Fred Fred 06/02/02 11:32PM
