Re: timing
Chris Robertson /
Hi:
The Ciao Workshop manual goes on to state:
<i>...normally impossible for the setting to be incorrect. The exception to the above rule is when the contact breaker points or fibre heel become worn...</i>
You <b>do</b> need to set the contact breaker gap.
The workshop manual says:
<i>If the contacts are in good condition, measure the gap using a feeler gauge. A 0.4mm (0.015 in.) gauge should be a light sliding fit (the points <b>must</b> be within the range: 0.35 - 0.45 mm (0.013 - 0.017 in.)).</i>
Hope this helps!
Chris.
  timingTopic by: VespaCIAO VespaCIAO 06/01/02 02:50AM
  Re: timingRe: DOUGLS SCHOLL DOUGLS SCHOLL 06/01/02 07:32AM
  Re: timingRe: bruce bruce 06/01/02 01:20PM
  Re: timingRe: Chris Robertson Chris Robertson 06/01/02 04:54PM
  Re: timingRe: Fred Fred 06/01/02 06:25PM
  Re: timingRe: bruce bruce 06/01/02 07:46PM
  Re: timingRe: Fred Fred 06/01/02 10:54PM
  Re: timingRe: bruce bruce 06/02/02 12:02PM
  Re: timingRe: Fred Fred 06/02/02 09:55PM
  Re: timingRe: bruce bruce 06/02/02 10:54PM
  Re: timingRe: Fred Fred 06/02/02 11:14PM
  Re: timingRe: Ron Brown Ron Brown 06/03/02 11:39AM
  Re: timingRe: Chris Rice Chris Rice 06/02/02 11:23PM
  retardedRe: Fred Fred 06/02/02 11:32PM
