grande, bad acceleration
My grande runs great and idles great but when I accelarate from a stop (while idling), it kind of jerks and shakes, like something's slipping, and then starts going. I dont think its the starting clutch, but maybe the drive clutch/pully? It has a new belt, greased variator, and the tranny has adequate gear oil.
Re: grande, bad acceleration
are the bolts on the swingarm tight? Is it easy to start?
yeah it's easy to start. what's the swingarm?
Check your three motor mount bolts to make sure they are tight.
Check the rear wheel mounting bolts to make sure they are tight (4 hex head bolts, 2 on each side).
Make sure the sub frame bolt holes for the rear wheels are not broken or torn.
alright, i'll do that and see if it helps
thanks
Also make sure the locking nut on the front speed regulator is tight and the locking washer is bent over so the nut won't come undone
Make sure you don't have grease in the pulley areas (front and back) and no grease on the belt. You can use a solvent like brake cleaner or electrical contact cleaner to clean the belt if it has grease on it.
Yeah, all of that checks out ok, and I checked all of those bolts and they were tight. I also noticed something else. When it's on the stand and I give it gas, it doesn't jerk or anything. But, I tried lightly holding the brake (to simulate resistance on the back wheel), and I could clearly see the clutch kind of jerking, too. Another thing; when I turn the clutch with my hand, it feels as if it has a lot of play in it. Maybe something's wrong in the tranny?
Thanks for the help.
Check the tranny for oil. Screw or hex head nut near the Free Wheeling button. If oil runs out you are OK, If not use 80-90 weight gear oil. Buy the Gera oil in the plastic bottle with the nose cone, makes it easy to fill the tranny.
Yep, just filled it a couple of weeks ago.
