Reenforcing stock forks.
I have done this a few times to my forks. See the brace across the top and bottom,, measure scribe and cut a couple out and tack it below the top plate. It works good on these sketchy disposables. And is out of sight!
(edited)
Re: Reenforcing stock forks.
Princess Rapunzel /
Jeremey reinforced his stock maxi forks by welding extra material on the bottom triple tree plate
Yes, it's in the first pic. ^ But that is still relying on the top plate bolts to hold the twist.
Jeremy Homser /
When i did my maxi forks i completely boxed in the bottom tripple tree. I welded a plate up top like yours but mine is vertical. I like how you did your upper support, next fork i do im stealing that.
yeah this works awesome for tomos forks, i've used a piece of round tube mitered on either side, but this probably works just as good with a lot less work.
maxi forks don't seem to need it as bad, i think the upper tripple stamping is tighter fitting and holds the tubes better.
