tomos wont start cant pedal backwards
So I replaced my head and cylinder gaskets today on my A3, now the pedal will not go backwards, therefore not allowing me to start it. The rear wheel does rotate backward and I can pedal it forwards. It ran fine just before this any ideas to what's my problem?
Re: tomos wont start cant pedal backwards
can you turn the flywheel? sounds like somethings stuck on assembly up top.
what did you find as the result of your prior thread?:
13. help with cylinder removal
brian kay — 3 days ago
cant seem to get the cylinder off my Tomos A3 motor . help me please
got the cylinder off, but destroyed it in the process.*( a lot of banging )
clean off the carbon buildup on the head and installed a spare cylinder
I took off the right pedal to straighten it could that have something to do with my problem.
forum decorum, move this to your other thread
no: I can pedal it forwards.
posted it twice my bad
kim jensen /
Yep when you took the pedal off, the shift moved and the large U shaped clip that engages the sit shaft gear for back pedal starting has come dis engaged. Remove pedal and clutch cover , engage clip in the space it needs to go while keeling pedal shaft pushed in. Re assemble!
remove cover on left or right side ?
I was also reading about a grease trick once I engage the clip .have you heard about that ?
