puch maxi engine differences?
I have a 1986 Puch Maxi with a single speed engine. I am trying to buy seals and bearings but am not sure if mine is a needs 3 seals the same (17/40/7) or 2 of these and a (22/40/7).
as my bike is a 1986 I'm assuming its the new model and i should go for the first option. Is there anyway to tell from the engine number.
Also are there any other differences i.e. bearing sizes?
cheers
Re: puch maxi engine differences?
Depends on what crank you're going to use. Most aftermarket cranks you will need the 22 mm id seal (except for this one https://www.treatland.tv/puch-E50-top-crankshaft-p/puch-top-crankshaft.htm ). The difference is in the seal journal that's right against the crank lobe on the clutch side. Most cranks have a larger journal, and a step to locate the bearing. Some, like the top crank, the journal od / seal id is the same id as the bearing, and you have to use a circlip in-between to locate the bearing.
GL
~M
