Bending pipe
Best ideas, suggestions to put a 20-30* angle on a 26mm header for a batavus. Best ways it can be done without crimping? or do I cut it off and weld it? Thanks
Re: Bending pipe
Muffler shop should be able to do it
Re: Bending pipe
Brent Bublitz /
Secure it in a vice. Get a plumbers torch, heat the bend point until it's glowing red, gently tug into shape, cool off. Takes about 10 minutes.
Re: Bending pipe
Tech-School
Re: Bending pipe
this
Re: Bending pipe
If you do this the packing tight of the sand will produce the best quality bend. If you are using heat too make sure the sand is dry and if you can weld the ends tight or use some other means to prevent the sand from getting less packed
