Pulley and belt for Kinetic TFR non variated.
Randy Johnson II /
http://m.1977mopeds.com/item/32303930
This is an awesome buy. No guessing on belt length and a 65mm pulley. My pulley was a 90-95 mm If I measured properly. Slower acceleration but it cruises in a lower rpm. I feel I am in a better torque spot at speed.
Re: Pulley and belt for Kinetic TFR non variated.
Dirty30 Dillon /
Kudos to you if you can run a 65mm pulley, I tried the 80 and it couldn't pull me through the hills in CT on a Ciao.
I imagine the take off has got to be dismal, just got an acquaintances Kinetic running just right and half the hills in my area have it down to 20 mph.
Randy Johnson II /
All I did was play with the stock clutch and it keeps the rpm's higher until around 25-30mph. That really helps with the pick up and hills.
I feel it should be mentioned that this does not fit 99% of the kinetic tfrs out there. Different output shaft on the trans
