Motori Minarelli 3 Speed Stator Question
john cervini /
This is a 3 speed manual shift engine. It's on a 70's Omer Lory. The stator number is 13373. The coil wire attatches directly to it. I'm wondering if there are any other stators that would work on this. Anyone know? Thanks
(edited)
Re: Motori Minarelli 3 Speed Stator Question
cdi it with a pietcard magic.. super easy. what direction does it spin and .. cev? (edited)
john cervini /
It spins counter clockwise and it's cev flywheel number 6925.
What's wrong with it? It looks like it just needs a good scrubbadub.
lol, whats wrong with it .. silly to ask.
the cam follower.. on the points arm.. worn the fuck out! "here use my glasses"
green cdi kit.. should work.
Probably Fred /
Looks like just points are shot
john cervini /
I can say that the can follower is worn and points are shot. I can't seem to find any info on the pietcard magic cdi setup. Are there more options? Any help is greatly appreciated. Thanks!
If the cam follower is that shot, I bet the cam itself is rusted and pitted.
the magic is.. buying the right pietcard that spins the correct way.. and measurements of the screw space are in order. i would upgrade the lighting coil also while you have it apart if you plan to drive it.
