Re: PUCH 3 SPPED MOPED maxi
Rob @t ATTN! Burrito /
They're split bearings, easy to install just make sure you measure up to shim correctly. Can't recall the number off hand but very common. If you pull one the number should be etched into the race. Last time I did mine the new bearings and crank were .about 5 thinner than stock. The engine is basically the same as the 4 speeds as well, lookup monza condor and some x30 I believe had those. Rad engines! Pitiful clutches though haha
