cady isodyne crank bearing
Anyone know where I can get a main bearing for an isodyne motobecane cady motor circa 1966?
Wouldnt mind other bits too but yhe bearing seems to have a special shoulder...
Thanks
Re: cady isodyne crank bearing
wow....appreciate you typing in all those links, thats incredibly
does anyone have any insight into the bearing used for crank on a ISODYNE motor? It is not a standard bearing and has a shoulder or taper on both sides of the OD in which a screw literally holds it in place.
Also, they are sealed with a gas resistant bearing grease from factory.
I accept chances are thin I will find a OEM bearing but the tapered shoulders on the edge of the OD makes this unique enough that ordering ala cart aint gonna work
Downhill Harvey (OFMC) /
15 x 42 x 19
You don't want a sealed bearing.
https://www.dropbox.com/s/9pmd1kjjjtenfxt/cady-c1.pdf
Much appreciated. Thanks.
