Re: Bicycle grips?
Born to be WillD /
you can't get the lock-on type grips (like those vans ones) over the throttle side.
You can generally use bicycle grips though.
it's just typically harder on the throttle side. depends alot on the rigidity of the grips too.
Many manufacturers also produce motocross or motorcycle versions that have the larger ID for throttle side.
