Re: Soft seize? Runs bogged down now?
B. ill /
Could be running lean or the carb may be crapped up
clean the carb....also make sure you have the rubber boot between the air box & carb on or it will run lean
  Soft seize? Runs bogged down now?Topic by: Wesley Burson Wesley Burson 07/20/14 10:59AM
  Re: Soft seize? Runs bogged down now?Re: B. ill B. ill 07/20/14 11:35AM
  Re: Soft seize? Runs bogged down now?Re: Wesley Burson Wesley Burson 07/20/14 11:39AM
  Re: Soft seize? Runs bogged down now?Re: Wesley Burson Wesley Burson 07/20/14 08:53PM
  Re: Soft seize? Runs bogged down now?Re: Probably Fred Probably Fred 07/20/14 12:47PM
  Re: Soft seize? Runs bogged down now?Re: Bob Selby Bob Selby 07/20/14 12:48PM
  Re: Soft seize? Runs bogged down now?Re: Wesley Burson Wesley Burson 07/20/14 12:55PM
  Re: Soft seize? Runs bogged down now?Re: Bob Selby Bob Selby 07/20/14 01:08PM
  Re: Soft seize? Runs bogged down now?Re: Wesley Burson Wesley Burson 07/20/14 01:20PM
  Re: Soft seize? Runs bogged down now?Re: Wesley Burson Wesley Burson 07/20/14 01:50PM
  Re: Soft seize? Runs bogged down now?Re: Wesley Burson Wesley Burson 07/20/14 01:39PM
  Re: Soft seize? Runs bogged down now?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/20/14 04:46PM
  Re: Soft seize? Runs bogged down now?Re: B. ill B. ill 07/20/14 05:49PM
  Re: Soft seize? Runs bogged down now?Re: Wesley Burson Wesley Burson 07/20/14 07:18PM
  Re: Soft seize? Runs bogged down now?Re: Don Ohio Don Ohio 07/20/14 07:19PM
  Re: Soft seize? Runs bogged down now?Re: Wesley Burson Wesley Burson 07/20/14 08:36PM
  Re: Soft seize? Runs bogged down now?Re: Wesley Burson Wesley Burson 07/20/14 04:53PM
  Re: Soft seize? Runs bogged down now?Re: Ryan . Ryan . 07/20/14 05:03PM
  Re: Soft seize? Runs bogged down now?Re: Wesley Burson Wesley Burson 07/20/14 05:06PM
  Re: Soft seize? Runs bogged down now?Re: Don Ohio Don Ohio 07/20/14 05:23PM
  Re: Soft seize? Runs bogged down now?Re: Wesley Burson Wesley Burson 07/20/14 05:28PM
  Re: Soft seize? Runs bogged down now?Re: Don Ohio Don Ohio 07/20/14 05:33PM
  Re: Soft seize? Runs bogged down now?Re: Probably Fred Probably Fred 07/20/14 07:40PM
  Re: Soft seize? Runs bogged down now?Re: Wesley Burson Wesley Burson 07/20/14 07:41PM
  Re: Soft seize? Runs bogged down now?Re: Don Ohio Don Ohio 07/20/14 08:35PM
  Re: Soft seize? Runs bogged down now?Re: Ryan . Ryan . 07/20/14 08:44PM
  Re: Soft seize? Runs bogged down now?Re: Ryan . Ryan . 07/20/14 08:59PM
  Re: Soft seize? Runs bogged down now?Re: Wesley Burson Wesley Burson 07/20/14 09:02PM
  Re: Soft seize? Runs bogged down now?Re: Ryan . Ryan . 07/21/14 04:08PM
