Soft seize? Runs bogged down now?
Wesley Burson /
My a3 tomos the motor stoped. While slowing down the motor started back up. It's running bogged down now. Could it just be hot I was riding wot for awhile
Thanks
Re: Soft seize? Runs bogged down now?
Could be running lean or the carb may be crapped up
clean the carb....also make sure you have the rubber boot between the air box & carb on or it will run lean
Wesley Burson /
Iheve no air box
Probably Fred /
Could be damage which is loss of compression and power
Remove top end and inspect for damage especially on the bottom of piston/rings and cylinder
So you really posted this thread before your bike even cooled down...patience......
Wesley Burson /
It runs perry bad. I'll try some things
How about be patient.....let it cool...then make sure you are not timed too high...a temp gauge would have prevented this problem... the saying haste makes waste is very true....
Wesley Burson /
When it's cool it runs fine it's when it's hot it runs like crap
Wesley Burson /
I posted this thread while I was at church. It was outside cooling
Wesley Burson /
Thinking now it's always kinda been that way.
> outside cooling.
Ha ha God will fix it just send him a E-Mail
Wesley Burson /
I realized it does not have the stock exhaust. So could the jetting be wrong?
Easily.
Wesley Burson /
Sweet I'll pick some up
Am I hearing you right,Wesley? You don't have an airbox? Do you have any restriction to clean the air? I would never run any of my engines without an airbox.I've also never had a seize of any kind. don-ohio
Wesley Burson /
The guy I got it from did not I have a sock on it now
Well,that'll help. don-ohio (:^)
> outside cooling
if you were paying attention in church & not texting, God would have told you to upjet
try some holy water in the gas tank
Wesley Burson /
First off not catholic. Second it was before service. And holy water is know to rust fuel tanks!
> tanks!
HaHaHaHaaaa! He's no fool,Bill! LOL! don-ohio (:^)
Probably Fred /
You know how to make holy water?
Boil the hell out of it! ha ha .
Wesley Burson /
Sometimes a good exorcism can solve air leaks!
HeHeHeee! Good one,Ken! (:^)
Wesley Burson /
So back to the topic haha where can I get jets locally?
You can't.
Wesley Burson /
Pry gonna sound stupid but could I drill the jet?
Done it, don't recommend it at all.
Wesley Burson /
Did it work?
It seized my Athena kit badly after 2000 miles of faithful service when I swapped to another bike, in 10 miles. Seemed to be running and jetted well too.. it's just very difficult to not be too far one way or the other. Even with the right bit you can over drill the jet just by the way you twist the bit in your hand. Also, for the cost of the bits you could buy several jets.
