How to stop overheating??
I installed a temp gauge and up jetted carb from 90 to 94 and it still gets pretty hot. Any tips?
Re: How to stop overheating??
Brent Bublitz /
Does it have gas in it?
Alex Nelson /
Yes?
i always upjet when i install a temp gauge......
Brent Bublitz /
I'm shocked the temp gauge didn't keep it cool. Mine won't break 350 with one installed.
The point of the snark is that you have told us nothing useful to help you diagnose your problem. What motor, what bike, what mods, what's your timing. Need to know it all.
Brent Bublitz /
Without looking, I'm guessing you have a Tomos.
Alex Nelson /
I upjetted because I overheated befor I got temp gauge
Alex Nelson /
I have a honda nu50 (urban express) and I have the dr 70cc kit installed ( still breaking in), circuit pipe, timings correct. 94 main jet with a hi flow filter
simon thokaar /
oil injector or premix? injector might not be working properly or you need more oil in the premix. If injector disabled did you block off all the lines.. could be drawing too much air. Id just keep upjetting til you hit a temp you like and the bikes not getting flooded.
What is the compression number?
And what do you consider to be overheating?
and what size carb ?
94 is fat.
Downhill Harvey (OFMC) /
I told ya not to kit so soon, breaking 30mph yet?
What temperature is "pretty hot". Is it like "pizza pocket hot"? "I just welded this and probably shouldn't touch it hot"? "Lava hot"?
Alex Nelson /
Stock carb, I know not ideal but it's what I got for now
Alex Nelson /
Did I before kit? Or now.
Probably Fred /
Retard timing if jetted correctly
^^^CDI, can't
Probably Fred /
Downhill Harvey Wrote:
> ^^^CDI, can't
Get a different box if possible .
Some cdi stators move
^^^you should try an Urban, you might like it.
Alex Nelson /
Represent NU50!
Tri-ped Dave O.D.B. /
what head? either air leak or compression too high. Did it soft seize from heat?
The overheating test is black oil under the piston dome.
On stock honda head's don't freak out till you hit 445f.
Honda, pug's and moby's are fine with WOT head temps running 410 to 440f.
Your loosing power till your at least 380f,
400f to 430f is the wot range you want, if your tune is golden.
Alex Nelson /
Ya it did
it could be an airleak where the decomp passage on the kit and gasket hits the urban head, see the pic, or maybe too lean with the high flow filter. my urban with kit & circuit was happy with a 95 jet and the stock airbox. you running premix or injector? try amsoil saber at 80:1
Heat comes from:
too much compression (Over 9:1 corrected compression ratio on an unpiped bike, over 15:1 Uncorrected compression ratio on a piped bike)
Incorrect combustion chamber shape (Squish band too wide/wrong angle/too much squish clearance)
Too much ignition advance (Varies by bike)
Running too lean/hitting a lean spot in your Carb setup
Insufficient cooling (Almost always a problem on Hobbit derivatives)
Follow Max's check list - since your making this a mystery for us I would just throw liquid nitrogen directory into flux capacitor
Alex Nelson /
i hit 425 today
