interchangeability
Fred /
Well.. all those parts I named are different from each other on the 2 models... but they will all SWAP.
soooo...
.. you can put the II cyl on the I.. (but they are not the same)
.. you can put the I manifold on the II... (but they are not the same)
and so on
(the reed valve from thr II will fit on the I after you carefully drill out the little locator packet a bit)
So... as far as I know... anything you get for the Camino fron 50ccnl... will fit on either one.
The only thing I don't know is how the I and II are different gearing wise.
  PA 50 FRED!!!!!Topic by: vapor vapor 05/28/02 11:03PM
  DudeRe: Fred Fred 05/28/02 11:26PM
  Re: DudeRe: vapor vapor 05/28/02 11:35PM
  interchangeabilityRe: Fred Fred 05/29/02 12:04AM
  Re: interchangeabilityRe: vapor vapor 05/29/02 12:43AM
  Re: DudeRe: David F Martin David F Martin 05/28/02 11:40PM
  Re: interchangeabilityRe: David F Martin David F Martin 05/29/02 12:20AM
