Re: Dude
vapor /
.....heay k-paso........i just wanted to make sure.........i want to make sure the big bore kit works on both .......and as far as i can surmize.........you said yes they will.......then at the end of your post you said the cylinders were different.......so ...................if the cylinders are not the same ........HOW can one kit work on both......................?
  PA 50 FRED!!!!!Topic by: vapor vapor 05/28/02 11:03PM
  DudeRe: Fred Fred 05/28/02 11:26PM
  Re: DudeRe: vapor vapor 05/28/02 11:35PM
  interchangeabilityRe: Fred Fred 05/29/02 12:04AM
  Re: interchangeabilityRe: vapor vapor 05/29/02 12:43AM
  Re: DudeRe: David F Martin David F Martin 05/28/02 11:40PM
  Re: interchangeabilityRe: David F Martin David F Martin 05/29/02 12:20AM
