Curious about this
Anthony Velasco /
Will a tomos a35 or a55 run with out the first gear installed. So what I'm saying is will the 2nd gear engage right away without the first gear not being there inside the clutch bell.
Re: Curious about this
I think it would.
It would engage later? :O
Anthony Velasco /
im curious if it will be sluggish off the line
no, the only thing splined directly to the shaft is the 1st gear clutch, it drives power back through the one way clutch into the second gear clutch until it spins fast enough to engage, then it overspins the one way clutch with first still engaged. its kindof a mindfuck how those engines work.
also speaking of things i'm curious... any of you guys into latex?
Can you weld the second gear to first gear and remove the teeth on first gear, or swap first with second? or make it so the second gear is splined to the shaft?
Overpriced Parts /
I have a latex allergy.
I can only wear vinyl gloves and hospitals don't like latex allergys.
I hear surgical procedure cost like $100 more if you have a latex allergy
i was just wondering last night if you could weld first gear to the shaft, then flip second gear and take the pads off and weld it to the bell, then weld first gear and second gear countershaft together, and get rid of the pedal shaft with a pullstart hooked directly to the one-way clutch?
or wait, no, actually i was wondering why people keep asking goddamn retarded questions about stupid things. just run it the way it was designed
if you have to ask you're not smart enough to do it. how about that.
FUCK!
simon thokaar /
used to date a gal witha latex allergy... buying special condoms got too damn expensive.
im allergic to latex too its great cause it gives me an excuse not to wear condoms
