maxi wiring
Has anyone tried this successfully? I wanted to cut down on the amount of wiring hanging off the side of my moped but don't know if this is the right approach or not.
http://hustleoverflow.com/mopeds/how-to-wire-a-puch-maxi-the-fast-way/
Re: maxi wiring
That will work. The tutorial didn't use the grey wire though. You can use the grey one for your tail light and the yellow for your headlight. You can also put the yellow and grey wire in the same spot on the wiring block and power headlight and tail light with both. Or you can leave it alone like in the tutorial. I usually use it though. (edited)
Re: maxi wiring
Re: maxi wiring
alex martino /
Hmm...ok I tried the diagram I posted but my spark plug has no spark now. I'm going to try and go with the digram from the wiki. thanks!
Re: maxi wiring
alex martino /
Got the first diy to work..just had a loose ground. Seems to be an ok method, not its time to hide everything.
