Velosolex 4600 Bulb replacement.
Hi there again..
Well, the already dim bulb in my Solex 4600 burned out earlier today as I was riding..
I unscrewed the front of the light from the back with the screw at the bottom.. I removed the whole front glass globe and reflector assy.. But have no idea how to get the bulb out.
The back of the reflector is held in with at least a dozen little bronze (Brass?) Clips.. I attempted to push some out of the way and one shot across my workshop...
Any Ideas? *Hint Hint* Brian *Hint Hint*
-Kori
Re: Velosolex 4600 Bulb replacement.
Andrew Squiggman /
unhook the headlight clips. that is how clips work. geez. this is getting tiring.
Mind explaining How someone does that? I "unhooked" One clip and it nearly put my eye out..
Also, Try not to be so put out when a New person asks a question.. You come off less as annoyed and more just as an asshole.. FYI
-Kori
Andrew Squiggman /
ok asshole, as that is how you are entering here. there are simple clips that hold your headlight. hook them in, or unhook them. what ever. it is really as simple as breathing air is.
Thank you kind sir.
